Hello
I am pulling some data from ethermine.org and also luno.com(luno I am using a wrapper provided by them GitHub - luno/luno-python: Python SDK for the Luno API and the ethermine calls I wrote myself) using a python script and telegraf, storing in influxdb and displaying it using grafana. I had it working until yesterday it stopped working and now my fields and measurements are not showing up on the influxDB UI, nor on grafana anymore. I tried checking the logs with sudo journalctl -u influxdb.service , but it doesn’t give me any useful info(I think?). Running my python script manually or via telegraf
(telegraf --config /etc/telegraf/telegraf.conf --input-filter exec --test) provides the expected output, but the data is just not showing up.
Will provide some screenshots of the log…if someone could please help me troubleshoot or tell me some tests I can run in order to determine where the fault has occurred I would be grateful.
I tried running influxd --log-level=debug, but the log still shows as lvl=info (see screenshot).
Here is my telegraf config:
[agent]
interval = "10s"
## Rounds collection interval to 'interval'
round_interval = true
## Telegraf will send metrics to outputs in batches of at most
## metric_batch_size metrics.
## This controls the size of writes that Telegraf sends to output plugins.
metric_batch_size = 1000
## For failed writes, telegraf will cache metric_buffer_limit metrics for each
## output, and will flush this buffer on a successful write. Oldest metrics
## are dropped first when this buffer fills.
## This buffer only fills when writes fail to output plugin(s).
metric_buffer_limit = 10000
collection_jitter = "0s"
## Default flushing interval for all outputs. Maximum flush_interval will be
## flush_interval + flush_jitter
flush_interval = "10s"
## Jitter the flush interval by a random amount. This is primarily to avoid
## large write spikes for users running a large number of telegraf instances.
## ie, a jitter of 5s and interval 10s means flushes will happen every 10-15s
flush_jitter = "0s"
## By default or when set to "0s", precision will be set to the same
## timestamp order as the collection interval, with the maximum being 1s.
## ie, when interval = "10s", precision will be "1s"
## when interval = "250ms", precision will be "1ms"
## Precision will NOT be used for service inputs. It is up to each individual
## service input to set the timestamp at the appropriate precision.
## Valid time units are "ns", "us" (or "µs"), "ms", "s".
precision = ""
## Logging configuration:
## Run telegraf with debug log messages.
debug = false
## Run telegraf in quiet mode (error log messages only).
quiet = false
## Specify the log file name. The empty string means to log to stderr.
logfile = ""
## Override default hostname, if empty use os.Hostname()
hostname = ""
omit_hostname = false
[[outputs.influxdb_v2]]
## urls exp: http://127.0.0.1:8086
urls = ["xxxxx"]
## Token for authentication.
token = "xxxxxx"
organization = "altus"
bucket = "altus"
[[inputs.cpu]]
## Whether to report per-cpu stats or not
percpu = true
## Whether to report total system cpu stats or not
totalcpu = true
## If true, collect raw CPU time metrics.
collect_cpu_time = false
## If true, compute and report the sum of all non-idle CPU states.
report_active = false
[[inputs.disk]]
## By default stats will be gathered for all mount points.
## Set mount_points will restrict the stats to only the specified mount points.
# mount_points = ["/"]
## Ignore mount points by filesystem type.
ignore_fs = ["tmpfs", "devtmpfs", "devfs", "overlay", "aufs", "squashfs"]
[[inputs.diskio]]
[[inputs.mem]]
[[inputs.net]]
[[inputs.processes]]
[[inputs.swap]]
[[inputs.system]]
[[inputs.exec]]
commands = ["python3 /usr/local/bin/main.py"]
data_format = "json"
interval = "120s"
name_suffix = "-ethermine"
name_override = "my_metric"
Here is my main.py python script:
import json
import requests
def Merge(dict1, dict2):
res = {**dict1, **dict2}
return res
from luno_python.client import Client
c = Client(api_key_id='xxxxx', api_key_secret='xxxxxxxx')
try:
result = c.get_ticker(pair='ETHZAR')
except Exception as e:
print(e)
# Miner - Statistics Altus
keyAltus = 'xxxx'
urlAltus = 'https://api.ethermine.org/miner/' + keyAltus + '/currentStats'
# PoolStats
urlPoolStats = 'https://api.ethermine.org' + '/poolStats'
statsAltus = requests.get(urlAltus)
statsPool = requests.get(urlPoolStats)
for key, value in result.items():
if type(value) is str:
try:
float_value = float(value)
except:
pass
else:
result[key] = float_value
mergedDict = Merge(statsAltus.json()['data'],statsPool.json()['data'])
mergedDict2 = Merge(mergedDict,result)
print(json.dumps(mergedDict2))
