Hello forum members,
I am trying to find the port that my pc uses to communicate with influxdb cloud.
I am sending data via node-red to https://ap-southeast-2-1.aws.cloud2.influxdata.com/
I need to list down the ports used due to “security reasons”
Please do let me know which port it uses to send data to the cloud!
Hi @subwayfootlong,
Could you link the Node-Red node pallet you are using to send data to InfluxDB Cloud? Most likely it will be sending the data via REST so you could try 80 and 443 as the defaults.
Hi @Jay_Clifford
I believe I am using the official one
this is the one I downloaded
@subwayfootlong,
It should be port 80 if using http. Or if you are using SSL then port 443.
