tomek
1
I’m trying connect my Fibaro to InfluxDB cloud:
How I defined:
I have for port 80:
[ERROR] sendDataToInfluxDB2 - Status is ERR - Status - 308 Data:
for port 8086:
[ERROR] sendDataToInfluxDB2 - Connection ERR - Connection timed out Data
What am i doing wrong?
Hi @tomek,
I personally haven’t used Fibaro but hopefully, we can help you get this working. Could you try adding:
https://eu-central-1-1.aws.cloud2.influxdata.com to IP
Port: 80 should be fine but you can also try 443
You could also try orgID or org name. I am not sure how this was implemented by FIBARO but if they are using the standard API it should work for cloud
tomek
3
Thank you, but it doesn’t work.
With
eu-central-1-1.aws.cloud2.influxdata.com and port 443 I have
sendDataToInfluxDB2 - Status is ERR - Status - 400 Data
and with https://eu-central-1-1.aws.cloud2.influxdata.com and port 443 I have:
Error in sendDataToInfluxDB2: std::runtime_error: ‘Invalid argument’
Hi @tomek,
It sadly sounds like an issue FIBARO needs to sort out since it doesn’t look like I can actively contribute
