I wanted to unistall influxDB using RaspOS (very similar to linux).
When I did the command sudo apt remove influxdb, everything worked fine, and I do not even see the package using sudo dpkg -l.
But when I use sudo apt update to install the latest kernel of my rasp, I see this error:
I don’t want to see it, please help.
