I configured several checks with an endpoint pointing to a URL
that monitored with an IBM OMNIbus HTTP_message_probe.
Sometimes I don’t get the “ok” events. Sometimes I stop getting any events.
Any known issue? Solution?
Thank you
Nati
Thank you
Nati
Hello @natim,
How did you configure your notification endpoint and notification rule?
How did you configure your check?
Hello @Anaisdg, I configured the endpoint as an HTTP post.
Then configured the nco_p_message_bus probe to listen on this URL.
Basically it works but sometimes it misses the “ok” notification when a check is solved and the alarm should be cleared (or other events) .
I also opened a case to IBM and they send me some properties to change, but still this issue keep happening.
When I notice the problem and I restart the probe the connection seems to reestablish again and it works fine for several hours.
Also I configured 2 notification rules:
1 - every 20s if Status is equal to CRIT
2 - every 20s if Status is changed from ANY to ok
No. It is on 0s.
Should I use it?
Yah you might be experiencing some read/write conflicts
