Hi here ![]()
I’m using InfluxDB 2.6 OSS in my homelab and I’m currently setting up monitoring for my home network using InfluxDBv2 alerting features. For now I’ve setup a few checks and I’m trying to report critical events using Telegram. I’m using OSS version, so no Telegram endpoint available in the UI. So I wrote the following task:
import "influxdata/influxdb/monitor"
import "contrib/sranka/telegram"
import "date"
option task = {name: "Notify on Telegram", every: 6m, offset: 20s}
notification = {
_notification_rule_id: "0000000000000001",
_notification_rule_name: "Notify on Telegram",
_notification_endpoint_id: "0000000000000002",
_notification_endpoint_name: "Notify on Telegram",
telegramToken = secrets.get(key: "TELEGRAM_TOKEN")
telegramChatID = secrets.get(key: "TELEGRAM_CHAT_ID")
telegramEndpoint =
telegram.endpoint(token: telegramToken, url: "https://api.telegram.org/bot")(
mapFn: (r) =>
channel: telegramChatID,
silent: false,
text: "*Notification triggered by check ${r._check_name}*: ${r._message}",
monitor.from(start: -6m)
|> filter(fn: (r) => r["_level"] == "crit")
|> filter(fn: (r) => r["_time"] >= date.sub(from: now(), d: 7m))
|> monitor.notify(data: notification, endpoint: telegramEndpoint)
But… it does not work. I’ve confirmed that token and chat id stored in secrets are correct by trying to send a test message using telegram.message and it works.
In the notifications history view, one can see that there are attempt to send notifications but there’s this warning icon on the right:
Right now I don’t see anything obviously wrong in my code, but I might be blind. Any idea or advices to help debugging ?
PS: I’m running Influxdb2 in docker using the official image.
Thanks.
