I’m running InfluxDB 2.17.11 on Windows Server 2022 with the TSM storage engine.
InfluxDB is connected to Telegraf and Grafana, and it works, but I keep seeing the following warning messages repeatedly in the InfluxDB logs:
2025-10-25T06:19:40.974137Z lvl=warn msg=“internal error not returned to client” log_id=0zjnDX1W000 handler=error_logger error=“context canceled”
Sometimes these occur every few seconds, even when system resources appear normal. Grafana panels occasionally take longer to refresh.
System Details
InfluxDB version: 2.17.11
OS: Windows Server 2022
Storage engine: TSM
Connected clients: Telegraf and Grafana
Load: ~3000 tags
interval = “15s”
round_interval = true
metric_batch_size = 1000
metric_buffer_limit = 40000
collection_jitter = “7s”
flush_interval = “10s”
flush_jitter = “7s” -
What I’ve Tried
Restarted InfluxDB and Telegraf services
Verified that both services are reachable over the network
Checked CPU, memory, and disk I/O — all are within normal ranges
Verified no large query load from Grafana
Questions
What exactly triggers the
context canceledwarning in InfluxDB 2.17.11? -
Does it indicate dropped writes, canceled queries, or client disconnections?
Are there any InfluxDB configuration parameters (timeouts, write buffer sizes, or query limits) that can be tuned to prevent this?
Could the Telegraf batch or jitter settings contribute to this issue under moderate load (3000 tags, 15s interval)?
Goal
To identify and fix the root cause of these recurring warnings so the system runs cleanly under load and avoids potential data loss or query interruptions.
