InfluxDB 2.1.1 backup is slow
We have an issue with backup execution time, it’s taking too long time, around 1 day and 20 hours.
Currently we are using influxDB 2.1, the total databases size is 500GB.
Before 1 months, we upgraded from 1.8.4 to 2.1.1, the execution time for backup before the upgrade was 2 hours only.
Directly after the upgrade, the backup took around 20 hours, then after one week, the backup taking longer time and backup finished in around 1 day and 20 hours.
Any idea, why the backup taking longer time after the upgrade? which its is increase from 2 hours to 1 day and 20 hours
Any suggestion to reduce the backup time?
Best Regard
Hello @samir_qh,
I’m not sure. Can you please file an issue here:
Unless @mhall119 have you seen this before?
Hi @Anaisdg
Thank you for your suggestion, I filed an issue there and hope to find the solution for my issue
