InfluxDB 1.8 – All data disappeared after changing retention policies
Hi there,
I’m trying to understand what happened with my InfluxDB instance because all data prior to Feb 4 disappeared, and I suspect it may be related to changes I made to the retention policies.
My version:
InfluxDB shell version: 1.8.10
System context
Earlier that day some system maintenance was done:
475 2026-02-04 07:54:54 : apt update
478 2026-02-04 07:55:26 : apt upgrade
483 2026-02-04 08:01:18 : apt autoremove
InfluxDB logs
Later in the logs I can see this error related to disk space:
Feb 04 09:30:00 monitor influxd-systemd-start.sh[521]: ts=2026-02-04T08:30:00.005840Z lvl=info msg="Executing query" log_id=0zVLdLXl000 service=query query="SELECT mean(used_percent) AS used_percent FROM telegraf_intern.autogen.disk WHERE (host =~ /^proxmox$/ AND fstype = 'ext4') AND time >= now() - 6h AND time <= now() - 30s GROUP BY time(1m), path"
Feb 04 09:30:00 monitor influxd-systemd-start.sh[521]: ts=2026-02-04T08:30:00.306211Z lvl=info msg="Error writing snapshot" log_id=0zVLdLXl000 engine=tsm1 error="error opening new segment file for wal (1): write /var/lib/influxdb/wal/telegraf/autogen/1709/_00024.wal: no space left on device"
Feb 04 09:30:01 monitor influxd-systemd-start.sh[521]: ts=2026-02-04T08:30:01.306270Z lvl=info msg="Error writing snapshot" log_id=0zVLdLXl000 engine=tsm1 error="error opening new segment file for wal (1): write /var/lib/influxdb/wal/telegraf/autogen/1709/_00024.wal: no space left on device"
So at that moment the disk was full.
Investigation commands
Later in the timeline, I found this in the history:
470 2026-02-04 08:18:09 : ncdu /
This particular one was earlier, during maintenance, but I don’t think anyone deleted the information from using -d in the ncdu interface.
460 2026-02-04 10:47:11 : influx
461 2026-02-04 10:47:37 : df -h
462 2026-02-04 10:52:58 : du -sh /var/lib/influxdb/data/*
463 2026-02-04 10:54:14 : du -sh /var/lib/influxdb/data/telegraf/* | sort -h
464 2026-02-04 10:54:14 : du -sh /var/lib/influxdb/data/telegraf_intern/* | sort -h
465 2026-02-04 10:54:39 : du -sh /var/lib/influxdb/data/telegraf/autogen/* | sort -h
466 2026-02-04 10:54:39 : du -sh /var/lib/influxdb/data/telegraf_intern/autogen/* | sort -h
Retention policy changes
“Scrolling up” in the InfluxDB shell history, these commands were executed (in this order). Unfortunately I cannot know the when or how much time passed between them.
(I mean that I cannot know either the day or the time when they were executed in relation to the rest of the logs)
USE telegraf;
CREATE RETENTION POLICY "18months" ON "telegraf" DURATION 78w REPLICATION 1 DEFAULT;
USE telegraf_intern;
CREATE RETENTION POLICY "18months" ON "telegraf_intern" DURATION 78w REPLICATION 1 DEFAULT;
USE icinga2;
CREATE RETENTION POLICY "18months" ON "icinga2" DURATION 78w REPLICATION 1 DEFAULT;
SHOW RETENTION POLICIES ON telegraf;
SHOW RETENTION POLICIES ON telegraf_intern;
SHOW RETENTION POLICIES ON icinga2;
DROP RETENTION POLICY "autogen" ON telegraf;
DROP RETENTION POLICY "autogen" ON telegraf_intern;
DROP RETENTION POLICY "dades_18_mesos" ON telegraf_intern;
DROP RETENTION POLICY "autogen" ON icinga2;
What I was trying to do
I noticed there were several retention policies:
  • autogen
  • dades_18_mesos
  • others
InfluxDB seemed to be storing more than 18 months of data, so I assumed the policies might be overlapping.
My reasoning was:
  • autogen has infinite retention
  • dades_18_mesos had 18 months for example
So I thought that since autogen was infinite, it effectively included the 18-month data anyway.
Because of that, I:
  1. Created new 18-month retention policies
  2. Set them as DEFAULT
  3. Then dropped the autogen policies
I assumed that data within the new 18-month policies would remain, and only the rest would be deleted.
Problem
All data prior to Feb 4 disappeared :sob:
Question
Did dropping the autogen retention policy delete all the data that was stored under it?
Even though I created the new 18months retention policy before dropping autogen, could that still have caused the loss of historical data?
Or could the disk full situation have played a role in this? or even the “upgrade” ¿?
Any clarification about how InfluxDB handles retention policy deletion and data migration (or lack of it) would be very helpful
Dropping the autogen retention policy indeed deleted all the data that was stored under it. This is explained with a warning in the documentation: “Dropping a retention policy will permanently delete all measurements and data stored in the retention policy.” The logic here is that if you want to change the duration of a retention policy, you can use ALTER RETENTION POLICY. A retention policy is the definition of how and how long to keep your data, so if you delete the entire policy, you also delete the data it was retaining.
Hi, thanks for the reply :slight_smile:
Yes, I saw it, but I thought that by defining the 18-month retention 1st it would save the 18 months on one side and then remove the autogen separately. So I understand now that it might have happened because of that… :thinking:
However, right after doing it I was still seeing data in Grafana (ruling out that it was the browser cache, since by default I usually refresh pages when I test something)
Could it be that I checked before the retention enforcement ran and the shard hadn’t been deleted yet?
There are a few things that don’t quite add up for me.
For example, in the telegraf database, if I check the shards the oldest one is from Feb 2:
id   database retention_policy shard_group start_time           end_time            expiry_time
1716 telegraf 18months         1716        2026-02-02T00:00:00Z 2026-02-09T00:00:00Z 2027-08-09T00:00:00Z
But in that same database, if I query the data, the oldest value I get is:
select * from cpu order by time asc limit 1;
which corresponds to Wed Feb 04 2026 07:57:00.
Shouldn’t it at least correspond here and start on February 2?
The strange thing is that I normally start working at 08:00, so I wasn’t even logged in at that time. In fact, the first commands in my shell history that day are from another colleague, I mean.
07:54:54 apt update
07:55:26 apt upgrade
08:01:18 apt autoremove
I’m not trying to overthink it, but I’d like to be sure about what actually happened :frowning:
Unfortunately, we can be pretty confident that deleting the retention policy deleted the data. I think the artifacts and inconsistencies you’re seeing leftover are likely some mix of various caches - whether InfluxDB’s caching, Grafana’s caching, or browser caching, along with your hypothesis that you checked before the retention policy was fully run, and not all of the data had been deleted/cleaned up yet.
thank u for your reply / explanation :sob: :heart_hands:
