Looks like the retention policy is not working, the idea of setting the retention policy is that data after that date is going to be purged? So why do I still have it?
(ps at setting the retention policy, I deleted samples older)
[@ ~]# influx
Connected to http://localhost:8086 version 1.7.6
InfluxDB shell version: 1.7.8
use collections;
Using database collections
precision rfc3339
select * from interface_tx order by time asc limit 5
time host instance type value
2019-05-02T00:00:01.484483146Z c03 tun1 if_packets 9534649
2019-05-02T00:00:01.484490055Z c03 tun1 if_octets 3181992971
2019-05-02T00:00:01.484495104Z c03 tun1 if_errors 36709
2019-05-02T00:00:01.484500411Z c03 tun1 if_dropped 0
2019-05-02T00:00:01.484626996Z c03 eth4.601 if_packets 1554831584
SHOW RETENTION POLICIES ON collections
name duration shardGroupDuration replicaN default
autogen 3648h0m0s 168h0m0s 1 true
[@~]# date -d “-152 days”
Sat May 4 21:50:29 CEST 2019
(ps. maybe take into account the influx command line with the formatting options here, so they are not causing some crappy layout, when pasting text)
