Hello
I need your helpon this. After changing flux-enabled = true in /etc/influxdb/influxdb.conf influxd does not start.
pi@serverPi4b:~ $ influxd version
InfluxDB v1.8.9 (git: 1.8 d9b56321d579)
Starts with flux-enabled = false:
pi@serverPi4b:~ $ sudo systemctl status influxd.service
? influxdb.service - InfluxDB is an open-source, distributed, time series database
Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
Active: active (running) since Wed 2021-08-11 12:21:38 CEST; 4h 17min ago
Docs: https://docs.influxdata.com/influxdb/
Process: 605 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=0/SUCCESS)
Main PID: 609 (influxd)
Tasks: 14 (limit: 4915)
CGroup: /system.slice/influxdb.service
+-609 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
Does not start with flux-enabled = true:
pi@serverPi4b:~ $ sudo systemctl restart influxd.service
Job for influxdb.service failed because the control process exited with error code.
See "systemctl status influxdb.service" and "journalctl -xe" for details.
pi@serverPi4b:~ $ systemctl status influxdb.service
Active: activating (start) since Wed 2021-08-11 16:41:26 CEST; 7s ago
Cntrl PID: 3193 (influxd-systemd)
Tasks: 13 (limit: 4915)
+-3193 /bin/bash -e /usr/lib/influxdb/scripts/influxd-systemd-start.sh
+-3194 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
+-3249 sleep 1
Aug 11 16:41:26 serverPi4b systemd[1]: Starting InfluxDB is an open-source, distributed, time series database...
Aug 11 16:41:26 serverPi4b influxd-systemd-start.sh[3193]: Merging with configuration at: /etc/influxdb/influxdb.conf
Aug 11 16:41:26 serverPi4b influxd-systemd-start.sh[3193]: ts=2021-08-11T14:41:26.343410Z lvl=info msg="InfluxDB starting" log_id=0VuQQNHl000 version=1.8.9 b
Aug 11 16:41:26 serverPi4b influxd-systemd-start.sh[3193]: ts=2021-08-11T14:41:26.344039Z lvl=info msg="Go runtime" log_id=0VuQQNHl000 version=go1.13.8 maxpr
journalctl -xe
-- Defined-By: systemd
-- Support: https://www.debian.org/support
-- The unit influxdb.service has entered the 'failed' state with result 'exit-code'.
Aug 11 16:41:47 serverPi4b systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
-- Subject: A start job for unit influxdb.service has failed
-- A start job for unit influxdb.service has finished with a failure.
-- The job identifier is 1687 and the job result is failed.
Aug 11 16:41:47 serverPi4b systemd[1]: influxdb.service: Service RestartSec=100ms expired, scheduling restart.
Aug 11 16:41:47 serverPi4b systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 7.
-- Subject: Automatic restarting of a unit has been scheduled
-- Automatic restarting of the unit influxdb.service has been scheduled, as the result for
-- the configured Restart= setting for the unit.
Aug 11 16:41:47 serverPi4b systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
-- Subject: A stop job for unit influxdb.service has finished
-- A stop job for unit influxdb.service has finished.
-- The job identifier is 1750 and the job result is done.
Aug 11 16:41:47 serverPi4b systemd[1]: Starting InfluxDB is an open-source, distributed, time series database...
-- Subject: A start job for unit influxdb.service has begun execution
-- A start job for unit influxdb.service has begun execution.
-- The job identifier is 1750.
Aug 11 16:41:47 serverPi4b influxd-systemd-start.sh[3325]: Merging with configuration at: /etc/influxdb/influxdb.conf
Aug 11 16:41:47 serverPi4b influxd-systemd-start.sh[3325]: ts=2021-08-11T14:41:47.846738Z lvl=info msg="InfluxDB starting" log_id=0VuQRgHW000 version=1.8.9 b
Aug 11 16:41:47 serverPi4b influxd-systemd-start.sh[3325]: ts=2021-08-11T14:41:47.846793Z lvl=info msg="Go runtime" log_id=0VuQRgHW000 version=go1.13.8 maxpr
lines 1643-1682/1682 (END)
-- The job identifier is 1561 and the job result is failed.
Aug 11 16:41:26 serverPi4b systemd[1]: influxdb.service: Service RestartSec=100ms expired, scheduling restart.
Aug 11 16:41:26 serverPi4b systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5.
Aug 11 16:41:26 serverPi4b systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
-- The job identifier is 1624 and the job result is done.
-- The job identifier is 1624.
Aug 11 16:41:36 serverPi4b influxd-systemd-start.sh[3193]: Failed to reach influxdb http endpoint at http://localhost:8086/health
Aug 11 16:41:36 serverPi4b systemd[1]: influxdb.service: Control process exited, code=exited, status=1/FAILURE
-- Subject: Unit process exited
-- An ExecStart= process belonging to unit influxdb.service has exited.
-- The process' exit code is 'exited' and its exit status is 1.
Aug 11 16:41:36 serverPi4b systemd[1]: influxdb.service: Failed with result 'exit-code'.
-- Subject: Unit failed
Aug 11 16:41:36 serverPi4b systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
-- The job identifier is 1624 and the job result is failed.
Aug 11 16:41:37 serverPi4b systemd[1]: influxdb.service: Service RestartSec=100ms expired, scheduling restart.
Aug 11 16:41:37 serverPi4b systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 6.
Aug 11 16:41:37 serverPi4b systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
-- The job identifier is 1687 and the job result is done.
Aug 11 16:41:37 serverPi4b systemd[1]: Starting InfluxDB is an open-source, distributed, time series database...
-- The job identifier is 1687.
Aug 11 16:41:37 serverPi4b influxd-systemd-start.sh[3261]: Merging with configuration at: /etc/influxdb/influxdb.conf
Aug 11 16:41:37 serverPi4b influxd-systemd-start.sh[3261]: ts=2021-08-11T14:41:37.122440Z lvl=info msg="InfluxDB starting" log_id=0VuQR1OW000 version=1.8.9 b
Aug 11 16:41:37 serverPi4b influxd-systemd-start.sh[3261]: ts=2021-08-11T14:41:37.122532Z lvl=info msg="Go runtime" log_id=0VuQR1OW000 version=go1.13.8 maxpr
Aug 11 16:41:47 serverPi4b influxd-systemd-start.sh[3261]: Failed to reach influxdb http endpoint at http://localhost:8086/health
Aug 11 16:41:47 serverPi4b systemd[1]: influxdb.service: Control process exited, code=exited, status=1/FAILURE
Aug 11 16:41:47 serverPi4b systemd[1]: influxdb.service: Failed with result 'exit-code'.
