Hi all.
I’m testing InfluxCloud to see if we could use it for a production deployment (we require the HA features).
To test it we started a trial cluster, loaded a set of data we already had used for our internal single node instance and created a continuous query.
The problem is that it appears the cluster is broken. A simple show databases sometimes works, sometimes it doesn’t. The same applies for all basic commands. Running a complex query fails every time.
Is there something we need to take into account when importing data to the cluster? Consistency maybe?
Any hint is welcome!
