Heya,
I just setup a influxdb cloud instance, renamed the influxdb bucket, and now I can’t use the data explorer panel. It says “failed to load buckets”.
I can’t fix this, any clue someone ?
Regards
Heya,
Regards
Hi @mandrag,
Apologies for the delay. Did you resolve your issue, or is this still a problem for you?
Nope I couldn’t sort it out. The data explorer keeps complaining about the buckets
I tried recreating one with the default name, that didn’t work.
I have the same problem. Anyone knows how to fix it ?
Regards
