InfluxCloud load balancing
I was wondering if InluxCloud has a load balacing? If I have a cluster, does it do load balacing between the nodes? Is it easy to scale up and add a node if the current config is not enough?
I can’t seem to find the details in the documentation.
Okay I’ll write it here so someone can know if they wonder the same thing. I wrote to support and got a confirmation that there is load balancing in Influx Cloud and there is also auto scaling.
@Danielle_Paquette-Ha
Thanks for circling back and sharing your answer!
