Influx not connected / connection refused
I have problems with grafana/influx.
Influx is installed on a RaspberryPi4 with 4GB RAM in an ioBroker environment. After working flawlessly for some months recently it stopped working.
ioBroker log indicates error:
Error: connect ECONNREFUSED 127.0.0.1:8086
After a new install of influx and a restore of the database it worked again for some days but stopped now.
When calling “Influx” in monitor I get this response:
pi@raspberrypi:~ $ influx
Failed to connect to http://localhost:8086: Get http://localhost:8086/ping: dial tcp [::1]:8086: connect: connection refused
Please check your connection settings and ensure 'influxd' is running.
pi@raspberrypi:~ $
Influxd is running and listening
pi@raspberrypi:~ $ sudo netstat -tulpn | grep LISTEN |grep influx
tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      13217/influxd
pi@raspberrypi:~ $
indeed it seems to listen on 8088.
as you can see in the influxdb.conf the Port 8088 is not selected
# The values in this file override the default values used by the system if
# a config option is not specified. The commented out lines are the configurati>
# field and the default value used. Uncommenting a line and changing the value
# will change the value used at runtime when the process is restarted.
# Once every 24 hours InfluxDB will report usage data to usage.influxdata.com
# The data includes a random ID, os, arch, version, the number of series and ot>
# usage data. No data from user databases is ever transmitted.
# Change this option to true to disable reporting.
# reporting-disabled = false
# Bind address to use for the RPC service for backup and restore.
# bind-address = "127.0.0.1:8088"
wheras in http section the correct Port 8086 is configured.
[http]
  # Determines whether HTTP endpoint is enabled.
enabled = true
  # Determines whether the Flux query endpoint is enabled.
  # flux-enabled = false
  # Determines whether the Flux query logging is enabled.
  # flux-log-enabled = false
  # The bind address used by the HTTP service.
bind-address = ":8086"
I check the installation
pi@raspberrypi:~ $ sudo apt update
Get:1 http://archive.raspberrypi.org/debian bullseye InRelease [23.7 kB]
Get:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15.0 kB]
Hit:3 https://packages.grafana.com/oss/deb stable InRelease
Hit:4 https://repos.influxdata.com/debian bullseye InRelease
Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
Get:6 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages [13.2 MB]
Get:7 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [297 kB]
Fetched 13.6 MB in 9s (1,503 kB/s)
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
All packages are up to date.
pi@raspberrypi:~ $ apt policy influxdb*
influxdb-client:
  Installed: (none)
  Candidate: 1.6.7~rc0-1
  Version table:
     1.6.7~rc0-1 500
        500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
influxdb-dev:
  Installed: (none)
  Candidate: (none)
  Version table:
influxdb:
  Installed: 1.8.10-1
  Candidate: 1.8.10-1
  Version table:
 *** 1.8.10-1 500
        500 https://repos.influxdata.com/debian bullseye/stable armhf Packages
        100 /var/lib/dpkg/status
     1.6.7~rc0-1 500
pi@raspberrypi:~ $
Finally I tried again to call influx again and got this response:
pi@raspberrypi:/etc/influxdb $ influx
Connected to http://localhost:8086 version 1.8.10
InfluxDB shell version: 1.8.10
> show databases
ERR: Post http://localhost:8086/query?chunked=true&db=&epoch=ns&q=show+databases: dial tcp [::1]:8086: connect: connection refused
Suddenly it seems able to connect but cannot find any databases but still waiting for some input.
Has anybody an idea what I got wrong with this installation and how I can repair that?
Regards Gerhard
