Env
OS centos 8
Software influxdb Version 2.03
Influx CLI 2.0.3 (git: fe04d346df) build_date: 2020-12-15T01:00:16Z
remove influxdb 1.7
then install influxdb Version 2.03
And there is no " $HOME/.influxdbv2"
$HOME/.influxdbv2/credentials
So confuse how to add user name / password
and org in command line.
I fails with sample command. influxdb v2.0 write-data
############My operation and result ################
$ influx write -b test4 -f MyGeneration_Data.csv
Error: Must specify org-id, or org name.
$ influx write -b test4 -f MyGeneration_Data.csv org “abrazo”
Error: accepts at most 1 arg(s), received 2
similar issue
`influx dashboards` doesn't work when `--org` is specified · Issue #108 · influxdata/influx-cli · GitHub
After try
export INFLUX_TOKEN=<yourauthtoken>
Result is the same …
