when i get pulse value with range 1y
pulse data stopped 2024.06.03
but
when i get pulse value with range 1mo
i can get all recent datas which at 7/2, 7/3, 7/4…
why i can’t get all data? and how can i get one id’s all data?
@poi0322 What version of InfluxDB are you using? From the UI screenshots, this looks like an older version.
@scott
I’m using InfluxDB 2.0.9
Is newer version fixed this problem??
I updated influx to 2.7.6 but same problem occur
I’m curious, has the field type ever changed for the pulse field?
