I have been struggling to get the Influx CLI to function on one of my systems (windows server). I’ve set up Influx such that it uses TLS certificates from our certificate authority. All that seems to work fine for accessing the GUI and for writing data to influx from other applications, however the CLI is struggling.
The weird part is, the CLI is working fine on one system but not on the other, even though they are essentially identical. I’ve already tried rebooting the server. Both use v2.7.5. I’m running the CLI’s from the same VM that runs the InfluxDB instance I’m trying to connect, so it cannot be network related.
I’m open to suggestions.
Please and thanks
Hi bhuijlgredainku,
Honestly, it seems you have a connectivity issues - something between the CLI and the server.
Can I assume you have checked all the obvious possible impediments, ports, firewalls, router/NAT/redirection, etc?
Dave
I have even shut off the local firewalls completely. However, both the CLI and influxdb are running on the same system so I don’t think it even touches the firewalls at all.
tnc seems to agree with that as well.
I don’t know what else there could be at this point.
OK, so I think the next step is to see whether the server will answer. One of my collogues has offered the following test which you might try: curl -v https://influxdb:8086/ping
Hang in there, we’ll figure it out!
Thank for the help.
I have in the mean time gotten desperate enough to re-install influx completely. Now I’m on version 2.7.6, but it did not help.
Here’s the result, I don’t know what to make of that. I have ran this test on the working system too and it gave the same result there.
I’m asking for help - stay tuned.
I have tried something else. I took the TLS certificate off and reverted back to using http. The CLI does work under http. So I would suspect it is something to do with how influx (or rather influx_cli, because other applications have no problem connecting to it over https) is handling the TLS handshake.
Awesome, so connectivity can work between the two.
To ensure I understand your setup, it sounds like you have a locally running InfluxDB with some custom certificates on Windows?
Are those custom certificates installed on the client’s System Root Certificate store as well? The client will need access to them to validate the server’s certs.
Yes, they are signed by a custom certificate root authority (this root authority is set as trusted for all systems in the network). I use this particular server for the influx database and for dashboarding (Grafana). So I have both these programs pointed to the same certificate (I did not expect an issue with that as I have even more stuff running on the same certificate on the test server).
Ah, that was the issue.
What I had done is simply put the certificates in a folder, in my case E:\Install_dir\Active_SSL_Certificates, and then point the influx configuration to that folder.
I have now installed the certificate into the certificate store of the server and it works.
Thank you and also @David_Sprogis very much for your help in this!
