Index Inconsistency
Hi all. When I run influx_inspect verify-seriesfile, I get quite a few “index inconsistency” errors like the lines pasted below.
Can anyone suggest how to repair these?
2019-01-19T02:16:26.589793Z error Index inconsistency {“log_id”: “0D4z9zJl000”, “path”: “/var/lib/influxdb/data/_internal/_series”, “partition”: “00”, “id”: 1, “got_offset”: 5, “expected_offset”: 0}
2019-01-19T02:16:26.726176Z error Index inconsistency {“log_id”: “0D4z9zJl000”, “path”: “/var/lib/influxdb/data/_kapacitor/_series”, “partition”: “00”, “id”: 25, “got_offset”: 712, “expected_offset”: 0}
2019-01-19T02:16:26.726919Z error Index inconsistency {“log_id”: “0D4z9zJl000”, “path”: “/var/lib/influxdb/data/_kapacitor/_series”, “partition”: “01”, “id”: 34, “got_offset”: 949, “expected_offset”: 0}
2019-01-19T02:16:26.891847Z error Index inconsistency {“log_id”: “0D4z9zJl000”, “path”: “/var/lib/influxdb/data//_series”, “partition”: “01”, “id”: 26, “got_offset”: 303, “expected_offset”: 0}
2019-01-19T02:16:29.106959Z error Index inconsistency {“log_id”: “0D4z9zJl000”, “path”: “/var/lib/influxdb/data//_series”, “partition”: “01”, “id”: 42194, “got_id”: 2302570, “expected_id”: 0}
What version of InfluxDB are you running?
Influxdb 1.7.2 (Docker container)
Is there any recommended way to fix that error? I see the same problem in my database, too.
# influx_inspect verify-seriesfile -dir /var/lib/influxdb/data/
2019-04-07T17:40:23.161548Z     error   Index inconsistency     {"log_id": "0EfE1klG000", "path": "/var/lib/influxdb/data/_internal/_series", "partition": "03", "id": 4, "got_offset": 5, "expected_offset": 0}
2019-04-07T17:40:23.163579Z     error   Index inconsistency     {"log_id": "0EfE1klG000", "path": "/var/lib/influxdb/data/_internal/_series", "partition": "01", "id": 10, "got_offset": 63, "expected_offset": 0}
2019-04-07T17:40:23.167433Z     error   Index inconsistency     {"log_id": "0EfE1klG000", "path": "/var/lib/influxdb/data/_internal/_series", "partition": "02", "id": 11, "got_offset": 44, "expected_offset": 0}
2019-04-07T17:40:23.169752Z     error   Index inconsistency     {"log_id": "0EfE1klG000", "path": "/var/lib/influxdb/data/_internal/_series", "partition": "05", "id": 14, "got_offset": 62, "expected_offset": 0}
2019-04-07T17:40:23.173533Z     error   Index inconsistency     {"log_id": "0EfE1klG000", "path": "/var/lib/influxdb/data/_internal/_series", "partition": "04", "id": 5, "got_offset": 5, "expected_offset": 0}
2019-04-07T17:40:23.210691Z     error   Index inconsistency     {"log_id": "0EfE1klG000", "path": "/var/lib/influxdb/data/telegraf/_series", "partition": "00", "id": 409, "got_offset": 11818, "expected_offset": 0}
2019-04-07T17:40:23.213619Z     error   Index inconsistency     {"log_id": "0EfE1klG000", "path": "/var/lib/influxdb/data/telegraf/_series", "partition": "04", "id": 605, "got_offset": 16270, "expected_offset": 0}
I have the same problem here.
How can we fix index inconsistency errors ?
root@runtsdb001:~# sudo -u influxdb influx_inspect verify-seriesfile -dir /var/lib/influxdb/data/
2019-04-17T07:20:15.140328Z error Index inconsistency {“log_id”: “0ErYX830000”, “path”: “/var/lib/influxdb/data/***/_series”, “partition”: “00”, “id”: 2297, “got_offset”: 35451, “expected_offset”: 0}
2019-04-17T07:20:15.141302Z error Index inconsistency {“log_id”: “0ErYX830000”, “path”: “/var/lib/influxdb/data/***/_series”, “partition”: “01”, “id”: 2226, “got_offset”: 33497, “expected_offset”: 0}
2019-04-17T07:20:15.151288Z error Index inconsistency {“log_id”: “0ErYX830000”, “path”: “/var/lib/influxdb/data/***/_series”, “partition”: “04”, “id”: 5421, “got_offset”: 74567, “expected_offset”: 0}
2019-04-17T07:20:15.151322Z error Index inconsistency {“log_id”: “0ErYX830000”, “path”: “/var/lib/influxdb/data/***/_series”, “partition”: “06”, “id”: 6407, “got_offset”: 83999, “expected_offset”: 0}
2019-04-17T07:20:15.308222Z error Index inconsistency {“log_id”: “0ErYX830000”, “path”: “/var/lib/influxdb/data/***/_series”, “partition”: “01”, “id”: 1338, “got_offset”: 17126, “expected_offset”: 0}
2019-04-17T07:20:15.361514Z error Index inconsistency {“log_id”: “0ErYX830000”, “path”: “/var/lib/influxdb/data/_internal/_series”, “partition”: “05”, “id”: 6, “got_offset”: 5, “expected_offset”: 0}
2019-04-17T07:20:15.446883Z error Index inconsistency {“log_id”: “0ErYX830000”, “path”: “/var/lib/influxdb/data/poc/_series”, “partition”: “01”, “id”: 738, “got_offset”: 8375, “expected_offset”: 0}
2019-04-17T07:20:15.507189Z error Index inconsistency {“log_id”: “0ErYX830000”, “path”: “/var/lib/influxdb/data/test/_series”, “partition”: “06”, “id”: 71, “got_offset”: 442, “expected_offset”: 0}
We’re looking into this now. I’ll post an update when I know more!
Edit:
We have a fix in the works for this issue (fix(influx_inspect): verify-seriesfile with deleted index entries by zeebo · Pull Request #13458 · influxdata/influxdb · GitHub). Essentially, the errors you’re seeing are a symptom of hitting a bug in the verify-seriesfile, but they’re not real errors.
We are still using v. 1.7.9 and having this issue.
Is there any way to understand if we are hitting the bug reported here or facing a real issue?
Has the bug been fixed only in v 1.8?
