I am trying to import data from a csv file. I am following this tutorial: How to Write Points from CSV to InfluxDB | InfluxData. Here is what my csv file looks like:
time,rx,tx,total,avg.rate
1607971430000,7.21g,380.01m,7.68g,300.96k
1608057830000,2.87g,276.44m,2.13g,390.93k
When I do Show Measurements, here is what I get:
name
1.21g
4.87g
Are these tables? What am I doing wrong? And how do I take into account other columns, like tx, total, avg.rate, etc.?
Here is a snippet from my .conf file:
data_format = “csv”
Added by Me
Indicates how many rows to treat as a header. By default, the parser assumes
there is no header and will parse the first row as data. If set to anything more
than 1, column names will be concatenated with the name listed in the next header row.
If csv_column_names is specified, the column names in header will be overridden.
csv_header_row_count = 1
Indicates the number of rows to skip before looking for header information.
csv_skip_rows = 0
Indicates the number of columns to skip before looking for data to parse.
These columns will be skipped in the header as well.
csv_skip_columns = 1
The character reserved for marking a row as a comment row
Commented rows are skipped and not parsed
csv_comment = “#”
The column to extract the name of the metric from
csv_measurement_column = “rx”
Columns listed here will be added as tags. Any other columns
will be added as fields.
csv_tag_columns = [“tag_key”]
The column to extract time information for the metric
csv_timestamp_format must be specified if this is used
csv_timestamp_column = “time”
The format of time data extracted from csv_timestamp_column
this must be specified if csv_timestamp_column is specified
csv_timestamp_format = “unix_ns”
