Import Data not Working
So I have a large import file of line protocol data that looks like this:
# DDL
CREATE DATABASE cptdata
CREATE RETENTION POLICY oneyear ON cptdata DURATION 365d REPLICATION 1
# DML
# CONTEXT-DATABASE: cptdata
# CONTEXT-RETENTION-POLICY: oneyear
lpardata,partitionName=host1,frame=frame1 phys_cores_used=0.81 1533441720
lpardata,partitionName=host2,frame=frame2 phys_cores_used=0.52 1533441780
lpardata,partitionName=host3,frame=frame3 phys_cores_used=0.01 1533441840
When I import it I get this output:
$ influx -import -path=myimportfile.influx -precision=s
2018/10/19 14:29:23 Processed 100000 lines.  Time elapsed: 488.612792ms.  Points per second (PPS): 204661
2018/10/19 14:29:23 Processed 200000 lines.  Time elapsed: 982.878739ms.  Points per second (PPS): 203483
2018/10/19 14:29:24 Processed 300000 lines.  Time elapsed: 1.407458905s.  Points per second (PPS): 213150
2018/10/19 14:29:24 Processed 400000 lines.  Time elapsed: 1.874520048s.  Points per second (PPS): 213387
2018/10/19 14:29:25 Processed 500000 lines.  Time elapsed: 2.402448304s.  Points per second (PPS): 208121
2018/10/19 14:29:25 Processed 600000 lines.  Time elapsed: 2.862350222s.  Points per second (PPS): 209617
2018/10/19 14:29:26 Processed 700000 lines.  Time elapsed: 3.324955206s.  Points per second (PPS): 210529
2018/10/19 14:29:26 Processed 800000 lines.  Time elapsed: 3.918903014s.  Points per second (PPS): 204138
2018/10/19 14:29:27 Processed 900000 lines.  Time elapsed: 4.372104188s.  Points per second (PPS): 205850
2018/10/19 14:29:27 Processed 1000000 lines.  Time elapsed: 4.845329892s.  Points per second (PPS): 206384
2018/10/19 14:29:27 Processed 2 commands
2018/10/19 14:29:27 Processed 1001035 inserts
2018/10/19 14:29:27 Failed 0 inserts
But when I go to look and see whats in my measurement, I get nothing:
$ influx -database 'cptdata' -execute 'select count(*) from lpardata' -format 'column'
But it DOES create the database and measurement:
$ influx -execute 'SHOW DATABASES' -format 'column'
name
_internal
cptdata
$ influx -database 'cptdata' -execute 'SHOW MEASUREMENTS' -format 'column'
name
lpardata
And when I manually insert data from the shell, it works:
$ influx
Connected to http://localhost:8086 version 1.6.3
InfluxDB shell version: 1.6.3
> USE cptdata
> INSERT lpardata,partitionName=host1,frame=frame1 phys_cores_used=0.81 1533441720
> SELECT COUNT(*) FROM lpardata
time count_phys_cores_used
0    1
So, where the heck is my data if it was supposedly successfully imported?
Anyone has any idea? I ran into the same issue today, couldn’t see the data imported, but manual insert worked. Thanks.
I’m having this problem now as well.
Hi what is the result of
  Show retention policies
While connected to your database ?
What were the timestamps of your imported data ?
> show retention policies
name      duration   shardGroupDuration replicaN default
autogen   0s         168h0m0s           1        true
two_years 17472h0m0s 168h0m0s           1        false
And here’s the top few lines of my import file:
# DML
# CONTEXT-DATABASE: ee_fc4_metrics
# CONTEXT-RETENTION-POLICY: two_years
diagrams_published,org=funding_circle,novelty=new avi=3i,diagrams=1i,description="UK System Landscape" 1518134400
diagrams_published,org=funding_circle,novelty=new avi=3i,diagrams=2i,description="Funding Circle App (UK)" 1518480000
Do these queries return the same ?
 Select count(*) from “ee_fc4_metrics”.“autogen”.”diagrams_published”
 Select count(*) from “ee_fc4_metrics”.“two_years”.”diagrams_published”
Please also have a look here about shard duration settings when importing data …
Aha, that solves the mystery! The first returned nothing but the second returned the value I’d have expected. This led me to read up a little more on retention policies and now I understand that when I was running queries in the shell I was unknowingly querying the default retention policy (autogen), whereas my measurements (points?) had been written to a different retention policy, the one that I’d specified.
I think I understand how to proceed at this point. Thank you Marc for your help!
You are welcome Avi :slight_smile:
