Is there any setup procedure listed for the monitoring IBM DataPower appliances ?How is the SNMP monitoring setup using the MIB files?
Hi @krnv17,
While InfluxData doesn’t provide specific documentation for monitoring IBM DataPower appliances, you could start by taking a look at Telegraf’s SNMP input plugin documentation, which will allow you to collect data via SNMP and send it to InfluxDB.
Hi Noah,
Thanks for the response.Will look into the documentation.
Regards,
Kumar
