Newb Here!
I have influxDB and Grafana running on a small Windows 10 Pro server. It is gathering data from my SmartThings Hub and I can happily produce Graphs so I know it’s all working.
My Next step is to add SNMP data from my Router, NaS Drive and PC Server to give me a complete picture.
I started with my Synology NaS Drive as I found what I think is a package solution which will aid my learning curve.
The package is here: GitHub - jperillo/Synology_dashboard_grafana: A grafana dashboard for monitoring Synology NAS
I have got Telegraf up and running and am pretty sure it’s working as it created the Influx Database as specified.
I have enabled SNMP on my Synology NaS.
I have built the Telegraph config as Instructed. and rebooted Telegraf
However, it doesn’t collect any data. Looking at the logs in Telegraf input, not Output seems to be at fault. It keeps adding these line to the Error Log:
2019-01-22T07:32:00Z E! [inputs.snmp]: Error in plugin: initializing table : translating: exec: "snmptranslate": executable file not found in %PATH%
I suspect I need to install the SMNP plugin but can find no info about how to do this in a windows environment.
Also unsure about where to put the MIB director currently its at:
C:\Program Files\Telegraf\usr\share\snmp\mibs
Any help appreciated please!
