http://localhost:8086 these is not working
What steps did you do befoe seeing this, something seems to be missing in that.
please give me the installation steps
Hey Aman, if you’re trying to install InfluxDB, I’d recommend checking out our documentation:
These should have thorough walkthroughs. Different version of InfluxDB have different ways of accessing and visualizing data.
I think based on your screenshot, it looks like you’re trying to install and run v2. Make sure after you’ve installed it, you run influxd run in a terminal to start the Influx service. If you’re running v3, you’ll want to use the InfluxDB Explorer UI, which comes bundled in the installation scripts and can be accessed on port 8888 by default, not 8086.
