Hi I know from here: “https://docs.influxdata.com/flux/v0.65/stdlib/” there is a library for using flux. What I dont know is how to use that lib nor where to get that lib. Which language is that lib for anyway?
Can anybody help?
Can anybody help?
Hello @gehlsdorf,
Welcome!
Flux is a functional scripting and query language for InfluxDB. The Flux standard library includes built-in functions and importable packages that retrieve, transform, process, and output data.
It is used by default in InfluxDB v2.x. Flux is packaged with InfluxDB v1.8+ and does not require any additional installation, however it is disabled by default and needs to be enabled .
Look here to enable it in 1.8:
You might also find this blog useful:
Out of curiosity, how did you hear about Flux? Have you used InfluxDB before?
Hi, Thx for reply. I basically know what Flux is and how it is related to InfluxDB. I also already used it via Grafana-Plugin.
What I like to do next, is to code a Go program (or Javascript/TS/ etc. whatever is suitable), which uses the flux stdlib (from GitHub - influxdata/flux: Flux is a lightweight scripting language for querying databases (like InfluxDB) and working with data. It's part of InfluxDB 1.7 and 2.0, but can be run independently of those.). I already got the Go package. Do I need to comile that package first before I can do import “influxdata/influxdb/v1”?
