SELECT sum(“error”) / sum(“all”) FROM (SELECT sum(“count”) AS “all” FROM “$measurement_name” WHERE “transaction” = ‘all’ AND “application” =~ /^$application$/ AND $timeFilter GROUP BY time($__interval) fill(null)), (SELECT sum(“countError”) AS “error” FROM “$measurement_name” WHERE “transaction” = ‘all’ AND “application” =~ /^$application$/ AND $timeFilter GROUP BY time($__interval) fill(null))
@Sangeeta_Agarwal I think this will get you what you’re looking for:
import "regexp"
baseData = () => from(bucket: "example-bucket")
|> filter(fn: (r) => r._measurement == "${measurement}")
|> filter(fn: (r) => r.transaction == "all" and r.application == =~ regexp.compile(v: "${application}"))
|> filter(fn: (r) => r._field == "count" or r._field == "errorCount")
|> aggregateWindow(every: v.windowPeriod, fn: sum)
|> map(fn: (r) => ({_time: r._time, _value: r.errorCount / r.count}))
Thank you Scott.
But when I try the query I don’t get any results:
In Influx data explorer, I get No results. But there are errors but still it is not calculating
Oh, sorry. I iterated on the query and forgot to remove something. Try this:
import "regexp"
Hi Scott,
Thank you for the solution but this is not working. I don’t want to iterate through every row.
I need percentage errors which is
(countError/count).
Count = total number of request
countError = total number of failes request.
Ok, try this:
import "regexp"
|> sum()
|> duplicate(column: "_stop", as: "_time")
Thanks Scott. It worked
