InfluxQL count with subquery in Flux
Hi! In InfluxQL I used this subquery structure a lot to count in Grafana.
For example, for count “devices” with “status” = 0 :
SELECT count("device") FROM (SELECT last("value") as "status" FROM "measurement" WHERE $timeFilter GROUP BY "device") WHERE "status" = 0
I’ve been trying to translate it in Flux but I can’t quite understand how it would be.
Thanks!
Try this:
from(bucket: "<your bucket>")
  |> filter(fn: (r) => r["_measurement"] == "measurement")
  |> filter(fn: (r) => r["_field"] == "status")
  |> group(columns: ["devices"])
  // this gives the last status of each device
  |> last()
  // this gives the last status where value in 0
  |> filter(fn: (r) => r["_value"] == "0")
  // this collapses the results into one big table
  |> group()
  |> count()
This assumes that “devices” is a tag and has a unique name per device, like a mac address or something.
I might have misread what “status” is.
The above should work if your input in line protocol looks something like:
insert measurement,device=xyz status=1 timestamp
insert measurement,device=xyz status=0 timestamp
insert measurement,device=zzz status=0 timestamp
The count should be 2 in this case.
You are a boss, it works.
I have changed:
|> filter(fn: (r) => r["_value"] == 0)
because 0 is int not string.
Thanks a lot ! :clap: :clap:
