I have measurement/table like this in Influx database
| time |
machine_id |
_field |
_value |
| time1 |
1 |
status |
true |
| time2 |
2 |
status |
false |
| time3 |
1 |
status |
false |
| time2 |
2 |
status |
true |
Then I created a new table using the above data and Flux query:
(below table is grouped by id)
| machine_id |
last_false_time |
| 1 |
time3 |
| 2 |
time2 |
Now I have to find number of ‘true’ entries per machine since its last_false_time and store the result into a table.
Is there any way to achieve this outcome using Flux query?
Hi, could you please give any hint on this, @Anaisdg @scott
hello @Rahul_Sangwan,
Do you only have 2 machine_id? Or more?
If you have only 2 machines (or limited number) you could:
- extract the time3 and time2 with findRecord()
findRecord() function | Flux 0.x Documentation
- Then you could filter conditionally for each id and where time is greater than respective times and then count
Query using conditional logic in Flux | InfluxDB OSS 2.6 Documentation
Or if you have N machine ids and you don’t want to do that systematic approach you could instead:
- join data on machine_id
Join data in InfluxDB with Flux | InfluxDB OSS 2.6 Documentation
- then fill previous on the last_false_time
Fill null values in data | InfluxDB OSS 2.6 Documentation
- conditional filter where time > last_false_time
same docs as above
Let me know if you want example queries or if the documentation provided is enough to get you started.
Thank you!
