Convert from InfluxQL to FLUX query (Please Help)
Hello All,
@ [Anaisdg]
Can someone please help me to convert my old InfluxQL query to Flux query?
These query is being used in Grafana-7.x and InfluxDB 2.x.
InfluQL Query : SELECT mean(“value”) FROM /container.ops.*/ WHERE “environment” = ‘$env’ AND “region” =~ /^(?i)$region$/ AND “container” =~ /(?i)$container/ AND $timeFilter GROUP BY time($__interval) fill(null)
I tried below, but it’s not working as intended and i may be way off.
from(bucket: “bucket_name”)
|> filter(fn: (r) => r["_measurement"] == /container.ops.*/)
|> filter(fn: (r) => r[“container”] =~ /(?i)$container/)
|> filter(fn: (r) => r[“environment”] == “$env”)
|> filter(fn: (r) => r[“region”] =~ /^(?i)$region$/ )
|> group(columns: ["_time"])
|> yield(name: “mean”)
Kindly help me out converting these RegEx pattern properly.
Thanks for your time !
@Artificial_Brain Where is this query being executed? Grafana?
@scott Yes, it’s being used in Grafana-7.x. kindly help.
Hello @Artificial_Brain,
aggregateWindow() automatically groups data by time windows so you can calculate the mean over those windows.
where as
will group data on individual timestamps.
Can you try removing the group() function? Does that help you get what you’re looking for?
@Anaisdg thanks for your advice. But there’s a problem in RegEx. Hence query is not working properly.
It’s hard for me to understand how I can fix the regex without knowing what values you want to receive.
Are you aware of the strings package?
You might find success using
@Artificial_Brain,
Can you describe what you’re trying to filter for with regex so I can help you craft the correct regex? I find using a regex tester like
helpful.
Thanks!
@Anaisdg Thank you for replying.
I don’t want to put below hard coded values, this making query running very slow and spacious too.
|> filter(fn: (r) => r["_measurement"] == “container.ops.data.issueRates” or r["_measurement"] == “container.ops.data.ratePersmissions” or r["_measurement"] == “container.ops.data.financialSteps” or r["_measurement"] == “container.ops.data.examineDepth” or r["_measurement"] == “container.ops.data.localPayment” or r["_measurement"] == “container.ops.data.globalWellness” …so on )
|> filter(fn: (r) => r[“container”] == “PO-PS-ALOCA_AIRIAN” or r[“container”] == “PO-PS-ALOCA_CQPRXN” or r[“container”] == “PO-PS-ALOCA_FBSELO” or r[“container”] == “PO-PS-ALOCA_JSBORKF” or r[“container”] == “PO-PS-ALOCA_HBWSHJI” or r[“container”] == “PO-PS-ALOCA_NREPXL”)
|> filter(fn: (r) => r[“environment”] == “BETA” or r[“environment”] == “DEV” or r[“environment”] == “PROD” or r[“environment”] == “QA”)
|> filter(fn: (r) => r[“region”] == “rams” or r[“region”] == “paca” or r[“region”] == “manoa” or r[“region”] == “lapea”)
Therefore trying to use regex.
Yes I understand why you need regex. Thanks for sharing your original query so we can find the right regex. Alternatively I suggest using the string package shared above instead of regex as it might be easier but here’s a regex solution.
|> filter(fn: (r) => r["_measurement"] =~ /^container.ops.data./)
|> filter(fn: (r) => r["container"] =~ /^PO-PS-ALOCA_/)
The issue being ^(?i)$ matches an empty string, but the additional <string>$ prevents it from matching anything. I don’t understand why grafana is generating those regex.
Are $container and $region variables in Grafana? If so, what values do they have?
