hi I have telegraf.conf like this
[[inputs.sql]]
# ## Database Driver
# ## See https://github.com/influxdata/telegraf/blob/master/docs/SQL_DRIVERS_INPUT.md for
# ## a list of supported drivers.
# driver = "mysql"
driver = "sqlserver"
# ## Data source name for connecting
# ## The syntax and supported options depends on selected driver.
# dsn = "username:password@mysqlserver:3307/dbname?param=value"
dsn = "user:pass@192.168.101.11:1433/dbname?param=value"
# ## Timeout for any operation
# ## Note that the timeout for queries is per query not per gather.
# # timeout = "5s"
# ## Connection time limits
# ## By default the maximum idle time and maximum lifetime of a connection is unlimited, i.e. the connections
# ## will not be closed automatically. If you specify a positive time, the connections will be closed after
# ## idleing or existing for at least that amount of time, respectively.
# # connection_max_idle_time = "0s"
# # connection_max_life_time = "0s"
# ## Connection count limits
# ## By default the number of open connections is not limited and the number of maximum idle connections
# ## will be inferred from the number of queries specified. If you specify a positive number for any of the
# ## two options, connections will be closed when reaching the specified limit. The number of idle connections
# ## will be clipped to the maximum number of connections limit if any.
# # connection_max_open = 0
# # connection_max_idle = auto
# ## Specifies plugin behavior regarding disconnected servers
# ## Available choices :
# ## - error: telegraf will return an error on startup if one the servers is unreachable
# ## - ignore: telegraf will ignore unreachable servers on both startup and gather
# # disconnected_servers_behavior = "error"
[[inputs.sql.query]]
# ## Query to perform on the server
# #query="SELECT user,state,latency,score FROM Scoreboard WHERE application > 0"
query="SELECT acc_code FROM DBA_MANAGE.dbo.TSKMACCOUNT"
# ## Alternatively to specifying the query directly you can select a file here containing the SQL query.
# ## Only one of 'query' and 'query_script' can be specified!
# # query_script = "/path/to/sql/script.sql"
# ## Name of the measurement
# ## In case both measurement and 'measurement_col' are given, the latter takes precedence.
measurement = "acc_code"
# ## Column name containing the name of the measurement
# ## If given, this will take precedence over the 'measurement' setting. In case a query result
# ## does not contain the specified column, we fall-back to the 'measurement' setting.
#measurement_column = "sql"
# ## Column name containing the time of the measurement
# ## If ommited, the time of the query will be used.
# # time_column = ""
# ## Format of the time contained in 'time_col'
# ## The time must be 'unix', 'unix_ms', 'unix_us', 'unix_ns', or a golang time format.
# ## See https://golang.org/pkg/time/#Time.Format for details.
#time_format = "unix"
# ## Column names containing tags
# ## An empty include list will reject all columns and an empty exclude list will not exclude any column.
# ## I.e. by default no columns will be returned as tag and the tags are empty.
tag_columns_include = ["acc_code"]
# # tag_columns_exclude = []
# ## Column names containing fields (explicit types)
# ## Convert the given columns to the corresponding type. Explicit type conversions take precedence over
# ## the automatic (driver-based) conversion below.
# ## NOTE: Columns should not be specified for multiple types or the resulting type is undefined.
# # field_columns_float = []
# # field_columns_int = []
# # field_columns_uint = []
# # field_columns_bool = []
# # field_columns_string = []
# ## Column names containing fields (automatic types)
# ## An empty include list is equivalent to '[*]' and all returned columns will be accepted. An empty
# ## exclude list will not exclude any column. I.e. by default all columns will be returned as fields.
# ## NOTE: We rely on the database driver to perform automatic datatype conversion.
#field_columns_include = ["sql"]
field_columns_exclude = ["acc_code"]
after set like that no error happen but I can’t get data from bucket
any wrong about my configuration file
