I’ve setup a new v2 Influx DB instance (and was required to specify user name and password), but cannot connect to the DB using flux. How do I provide credentials in flux? Is there a command line option for this?
Thanks,
Alex
flux repl
> from(bucket:"nec") |> range(start: -1h)
Result: _result
Error: unauthorized access
> buckets()
Error: listing buckets from a remote host requires an organization to be set
