How to preprocess json_v2 with one timestamp for an array of values
I am running into problem processing our internal json data with telegraf and influxdb.
The data package looks the following:
“meta”: {
“sensor”: “VoltageL1”,
“normalized”: true,
“unit”: “V”,
“range”: 1000,
“maximum”: 1.0,
“sampletime”: 10000,
“numVal”: 1000
“starttime”: 133312145513450000,
“values”: [
229.692,
229.692,
229.692,
(truncated for brevity)
229.761,
229.761,
229.761,
229.761,
229.761
Is it possible to directly preprocess the timestamp with the given sampletime (1ms increment) in telegraf to save with the following format to influxdb
{“starttime”: 133312145513450000, “value”: 229.761},
{“starttime”: 133312145513450000, “value”: 229.761}, …
How would the resulting mqtt_consumer look like?
Thanks for any help in advance.
133312145513450000
This is 18-digits long. A typical nanosecond timestamp is 19-digits. It is probably not what you want. The current millisecond timestamp is 1686773738629, or 13-digits.
In any case, when you parse your JSON you can need to:
  1. Set the precision of the agent or the input to ms
  2. If parsing the JSON use the json_time_format = "unix_ms" option
