How to parse Snowflake log file?
I’m trying to have Telegraf parse the log file of the local Snowflake instance. It usually looks like this:
nohup: Input is ignored
2023/07/24 20:09:24 Proxy starting
2023/07/24 20:10:19 NAT type: restricted
2023/07/24 21:11:24 In the last 1h0m0s, there were 3 connections. Traffic Relayed ↓ 69528 KB, ↑ 2418 KB.
2023/07/24 22:11:24 In the last 1h0m0s, there were 13 connections. Traffic Relayed ↓ 622101 KB, ↑ 46242 KB.
2023/07/24 23:51:55 In the last 1h0m0s, there were 4 connections. Traffic Relayed ↓ 23649 KB, ↑ 5311 KB.
2023/07/25 00:51:55 In the last 1h0m0s, there were 7 connections. Traffic Relayed ↓ 123722 KB, ↑ 11554 KB.
2023/07/25 01:51:55 In the last 1h0m0s, there were 2 connections. Traffic Relayed ↓ 124297 KB, ↑ 5029 KB.
Here’s my current config:
[[inputs.tail]]
  # file(s) to tail:
  files = ["~/snowflake/proxy/snowflake.log"]
  from_beginning = false
  # name of the "Metric" (which I want to see in Grafana eventually)
  name_override = "snowflake_log"
  grok_patterns = ["%{CUSTOM_LOG}"]
  grok_custom_patterns = '''
SNOWFLAKEDATE %{YEAR}/%{MONTHNUM}/%{MONTHDAY} %{TIME}
CUSTOM_LOG %{SNOWFLAKEDATE:date} In the last 1h0m0s, there were %{NUMBER:snowflake_connections:int} connections. Traffic Relayed ↓ %{NUMBER:snowflake_downstream:int} KB, ↑ %{NUMBER:snowflake_upstream:int} KB.
  data_format = "grok"
How can I tell Telegraf to ignore lines that include any of the following keywords?
  • nohup:
  • Proxy starting
  • NAT type:
Sometimes, however, there are also errors that include phrases like stream not found. How can I tell Telegraf to use the value 0 for snowflake_connections, snowflake_downstream and snowflake_upstream if the log line contains the phrase stream not found?
Thank you!
@pixelcode I’m not sure I do understand your target setting correctly… With your grok pattern, the nohup:, Proxy starting and NAT type: (or any line not matching your pattern) will be ignored as the grok parser will not find a pattern match. You can see this when running Telegraf with --debug as this will also show when a line was not matched.
If you want additional information (e.g. the errors you mention), you need to provide additional grok-patterns for those lines. If you want to fill-in missing fields you should use the default processor or if you need more sophisticated logic you should look into the starlark processor which can also generate additional metrics etc…
The following processing seems to have solved it:
[[processors.defaults]]
  namepass = ["snowflake_metrics"]
  [processors.defaults.fields]
    snowflake_connections = 0
    snowflake_downstream = 0
    snowflake_upstream = 0
Also, I noticed that I Telegraf doesn’t recognise ~/snowflake/proxy/snowflake.log, but only /home/pi/snowflake/proxy/snowflake.log.
Also, I noticed that I Telegraf doesn’t recognise ~/snowflake/proxy/snowflake.log , but only /home/pi/snowflake/proxy/snowflake.log .
Well I guess you start Telegraf via systemd and thus the user that starts Telegraf is probably telegraf. So ~/snowflake/proxy/snowflake.log expands to ``/home/telegraf/snowflake/proxy/snowflake.log` or whatever the home-dir of that user is set to… :slight_smile:
