I have a custom log file with entries as given below
How to write a grok pattern to match this and output it to influxdb. I have been trying for a long time with no success.
[Tue, 18 Jul 2017 02:39:45 GMT] GET 200 /lectures/questions/150 2032 47.8.10.6 [17.427 ms] phone
[Tue, 18 Jul 2017 02:39:45 GMT] GET 200 /forums/fetch/lectures/31 2032 47.8.10.6 [8.398 ms] phone
[Tue, 18 Jul 2017 02:39:45 GMT] GET 304 /users/phone/2032 2032 47.8.10.6 [6.613 ms] phone
[Tue, 18 Jul 2017 02:40:06 GMT] GET 200 /lectures/summary 2032 47.8.10.6 [12.817 ms] phone
daniel
July 18, 2017, 5:54pm
2
I wrote a few tips in the logparser readme , have you seen these? I highly suggest working on your pattern one token at a time.
Thanks for the reply. I followed it and was able to find the pattern of all except timestamp.
%{WORD:method} %{NUMBER:resp} %{URIPATHPARAM:request} %{NUMBER:userid} %{IPORHOST:clientip} [%{NUMBER:resptime}%{SPACE}ms] %{WORD:device}
For the time I tried %{DATESTAMP_RFC2822: timestamp} but it says not matched.
Can I get some help here
Ok, I got the pattern. Thanks for the help.
If any body needs it the pattern to match time stamp is
^[(?%{DAY}, %{MONTHDAY} %{MONTH} %{YEAR} %{TIME} GMT)]
Here is an example of my log:
test.co:443 80.81.174.142 www.test.co [07/Nov/2017:09:53:34 +0200] 10524941 “GET /api/v1/company/jobs HTTP/1.1” 200 34653 “https://www.test.co/v/hunt ” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10_12_6) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36” WgFmfn8AAAEAAF7ZVwUAAAAB ad3doh5o6zpyk5zubtrck8ta2p1tz187
I added this to my telegraf.conf:
[[inputs.logparser]]
files to tail.
files = [“/var/log/apache2/other_vhosts_access.log”]
Read file from beginning.
from_beginning = false
Override the default measurement name, which would be “logparser_grok”
name_override = “apache_access_log”
For parsing logstash-style “grok” patterns:
[inputs.logparser.grok]
patterns = [“%{CUSTOM_LOG}”]
custom_patterns = ‘’’
CUSTOM_LOG %{DATA:host} %{IP:client} %{DATA} [%{HTTPDATE:ts:ts-httpd}] %{NUMBER:resp_time:tag} "(?:%{WORD:verb:tag} %{NOTSPACE:r$
I tried using http://grokdebug.herokuapp.com/ to make sure my custom pattern works, and it looks like it does, but no entries were created in influx DB
Tested with other patterns and log examples and it worked, so I guess I’m missing something in the [[inputs.logparser]].
Thanks a lot!
The examples in this post is now slightly outdated. For the new " grok_custom_patterns " format, see this update I wrote after not getting above 2017 examples to work in 2020 Telegraf: Custom log parsing with latest Tail Plugin, GROK and InfluxDB configuration
Hi I want to filter all the logs where the status code is above 500
Please suggest me either pattern or regex to achieve this
