My configuration is based on: Telegraf + InfluxDB + Grafana, I’m not using Kapacitor, Cronograf.
For this notification aspect is a way to have in Grafana if I’m not using Kapacitor, Cronograf?
[Server side]
telegraf-1.5.0-1.x86_64
grafana-4.6.3-1.x86_64
influxdb-1.4.2-1.x86_64
I’m trying something like in Nagios | Centreon, to have on home page all Services that are in WARNING/ CRITICAL status, somehow a filtering in order to see only the problems.
- It is feasible/ possible to have on the same Dashboard(with template or without template) where you have the services KPIs a top row where you can have some notifications panels (singlestat, etc) where you can see the services in WARNING/ CRITICAL status?
- Or is needed to have a separate Dashboard for this?
Any recommendation or docs for this, really appreciated.
Kind Regards,
