How to forward to influx db only particular field from the incoming json
I have the following type of metric being published on MQTT broker:
   "dev":[
         "id":"office-32413",
         "l_seen":1659379835655,
         "mac":"deadbeefdead"
         "id":"office-56228",
         "l_seen":1659379835706,
         "mac":"deaddeaddead"
   "n":2,
   "of":2
Pagination is here because the total count of the dev items may be super high, like thousands.
Before I added this pagination feature the message was just an array:
and the telegraf configuration for it that was perfectly working is:
[[inputs.mqtt_consumer]]
  servers = ["tcp://{{inventory_hostname}}:1883"]
  name_override = "engine-health-tags"
  qos = 0
  connection_timeout = 30
  topics = [
    "engine/+/h/+/t",
  persistent_session = true
  client_id = "engine-health-tags-telegraf"
  data_format = "json"
  json_string_fields = ["mac"]
  tag_keys = ["mac"]
What I am trying to achieve now is use Telegraf’s parser to get only the dev array from the incoming json and send it to Influxdb as a metric.
How should I change the above telegraf’s configuration to parse only the dev object from the paginated json so I keep the same data in the influx db as when there was no pagination?
Hi!
I would use the json_v2 parser to parse each object:
[[inputs.file]]
  files = ["./data.json"]
  data_format = "json_v2"
  [[inputs.file.json_v2]]
    [[inputs.file.json_v2.object]]
      path = "dev"
      tags = ["mac"]
For example, produced the following with your sample data:
file,mac=deadbeefdead id="office-32413",l_seen=1659379835655 1659381553000000000
file,mac=deaddeaddead id="office-56228",l_seen=1659379835706 1659381553000000000
The important part is the following, which I have updated from file to mqtt. You can then remove the data_format, json_string_fields, tag_keys keys and replace them with:
  [[inputs.mqtt.json_v2]]
    [[inputs.mqtt.json_v2.object]]
      path = "dev"
      tags = ["mac"]
Thank you @jpowers ! It works perfectly !
