I’m trying to get data from mqtt into Influxdb 2.0 and from there into Grafana. The data I have in MQTT is in this format:
"id": 452664778,
"channel": 0,
"from": 2130636288,
"payload": {
"hardware": 10,
"id": "!7efeee00",
"longname": "base0",
"shortname": "BA0"
"sender": "!7efeee00",
"timestamp": 1646832724,
"to": -1,
"type": "nodeinfo"
I have telegraf configured like this, since the above json is stored in the /msh topic:
[[inputs.mqtt_consumer]]
servers = ["tcp://192.168.1.10:1883"]
topics = [
"msh/#",
data_format = "json"
In my Influx query I now want to get all payload_voltage readings where from equals a certain value. I’m stuck at achieving that. I started with this query:
from(bucket: "iot")
|> filter(fn: (r) => r["_measurement"] == "mqtt_consumer")
|> filter(fn: (r) => r["_field"] == "from" or r["_field"] == "payload_voltage")
|> yield(name: "mean")
Then I tried to filter it like so:
from(bucket: "iot")
|> filter(fn: (r) => r["_value"] == 3394052642)
|> yield(name: "mean")
3394052642 is the _from value. So as I said, I want to get all payload_voltage values where _from = 3394052642.That however just leaves me with all the _from values which isn’t what I want.
Is this problem something I can achieve with my existing setup? I think the problem arises from the json structure: I can’t seem to connect all the different json-indentations in my database.
Looking forward to any little piece of advice!
Thanks!
pk
