Kapacitor 1.3.3
I’m trying to use http basic authentication with Kapacitor.
I’ve set these env variables:
KAPACITOR_HTTP_AUTH_ENABLED=true
KAPACITOR_HTTP_USERNAME=admin
KAPACITOR_HTTP_PASSWORD=*****.
I get an authentication error if I don’t supply a username in the get request. However, the authentication succeeds if I supply only a username, and the username can be anything, e.g.:
curl -G http://foo@localhost:9092/kapacitor/v1/config
The log shows:
[noauth] 2017/11/03 23:06:40 W! using noauth auth backend. Faked authentication for user foo
How do I get true authentication to work?
Thanks, Charlie
