I am trying to use environment variables for kapacitor as described:
root@8473620:/usr/src/app# printenv | grep KAPACITOR
KAPACITOR_INFLUXDB_1_USERNAME=myusername
KAPACITOR_INFLUXDB_1_PASSWORD=mysecretpassword
KAPACITOR_INFLUXDB_1_URLS_0=https://lonepine-dc17c6fc.influxcloud.net:8086
relevant kapacitor.conf lines
I have removed the values for
urls, username and password on the second entry as I’m assuming that’s inserted by the environment variables
[[influxdb]]
enabled = true
default = true
name = "localInflux"
urls = ["http://localhost:8086"]
username = ""
password = ""
ssl-ca = ""
ssl-cert = ""
ssl-key = ""
insecure-skip-verify = false
timeout = "0s"
disable-subscriptions = true
subscription-protocol = "http"
kapacitor-hostname = ""
http-port = 0
udp-bind = ""
udp-buffer = 1000
udp-read-buffer = 0
startup-timeout = "5m0s"
subscriptions-sync-interval = "1m0s"
[influxdb.subscriptions]
[influxdb.excluded-subscriptions]
_kapacitor = ["autogen"]
[[influxdb]]
enabled = true
default = false
name = "cloudInflux"
timeout = 0
startup-timeout = "5m"
http-port = 0
udp-bind = ""
udp-buffer = 1000
udp-read-buffer = 0
error:
ts=2018-09-27T19:53:17.110Z lvl=error msg="encountered error" service=run err="create server: invalid configuration: must specify at least one InfluxDB URL. To generate a valid configuration file run `kapacitord config > kapacitor.generated.conf`."
Any help on what I’m missing would be much appreciated!
