Hello Everyone,
We have written a docker-compose file which spins up two influxdb instances running on ports 8086, 8087 and one kapaciotor instnace running on port 9092 locally. We are trying to implement multiple influxdb configurations in kapacitor.conf file, so that, kapacitor uses default influx instance for reading data and uses the second influxdb instance for writing the data.
We have added one more influxdb section, to kapacitor.conf file as below
[[influxdb]]
enabled = true
name = “default”
default = true
urls = [“http://influxread:8086”]
[[influxdb]]
enabled = true
name = “write”
default = false
disable-subscriptions = true
urls = [“http://influxdb-write:8087”]
and trying to configure kapacitor to write data to second influxdb instance using tickscript, as below.
var data = stream
|from()
.database(‘telegraf’)
.retentionPolicy(‘autogen’)
.measurement(‘cpu’)
.groupBy(‘host’)
.where(lambda: “cpu” == ‘cpu-total’)
|InfluxDBOut()
.cluster(‘write’)
.create()
.database(‘check_db’)
.measurement(‘check’)
but we are facing the error “No such config write” while enabling the kapacitor task. can anyone please provide a solution for this.
