Hi there I created a Banana PI R1 device that monitors and catalogs all network parameters and activity from remote servers and Internet connects - you simply plug it in and it snoops the entire network cataloging it usage, speeds, ping results .ETC ( pretty much everything) then once a day sends the data to influxDB it monitors 50 servers and internet connection in remote areas of the world as it acts as either router or a transparent bridge - i built the software so that you simple flash an SD insert it into the PI and it up and running in 30 seconds my problem is there seams to be a bug in influx as it will create a database based automatically on the INFLUXDB server in the MAC format and everything works as expected I used the MAC as an easy identifier as IPs change so do server names MACs stay the same — BUT you can not drop it later on - it will give you an error
example :DROP DATABASE 02:07:06:XX:XX:XX
ERR: error parsing query: found 02, expected identifier at line 1, char 15
is there anyway to delete these DataBases now after they being created or am I missing something
although this may seem immaterial in your environment, that’s an invalid filename on Windows; think it’s best to allow for a test env to be set up on a Windows box
MACs don’t stay the same if the NIC is swapped (and there are also user-settable MACs); if there’s a chance the device might have a partial field replacement you should use another unique identifier
thanks will give that a try tomorrow – not connected to the server at the moment. - I am using a linux environment so the file name is okay- as to swapping out NIC they are built in on BPI R1 ( actually 5 ports 6 if you include the wifi). perhaps i can format the MAC into a windows friendly dash or underscore… MAC is derived not from the servers but the PI as it the one transmitting the data… - truthfully there no way to change the MAC on theses devices even via a software switch ( as I have tried) - the way it calls the MAC it always brings up the original MAC … so as an identifier it is pretty good- even if someone steals one of the 50 devices - as soon as it calls home it automatically lists it current iP the provider and location of the device.
I was talking about the remote device’s MAC, yes. I suppose the remaining question is if someone steals one of the devices, do you want to have a continuous series of data from that location. I wouldn’t use the MAC myself but a GUID.
thank you that worked with the double quotes to delete the database–
curious do you know of any way to to import a CSV to influxdb I tried a couple but they do not seam to preserve the the timestamp cvs to influx it finds the time stamp but does not preserve it
I don’t know exactly what you mean by finds-but-does-not-preserve but to import, as far as I am aware, you can’t use an actual CSV. You have to use what I’ve nicknamed an “IDV” (Influx Delimited Values) file which follows the line protocol in the docs. (It’s comma-delimited tags, a space, comma-delimited fields, a space, timestamp.)
if it does not locate the timestamp properly, it inserts the timesamp as and extra item… I will try converting the timestamps to unix timestamp and see it makes a difference but I think it probably not going to work … but I will give it a try… the reason is I use on the pi devices RRD containers to store info locally. and when you login to the device it will display all data in a nice visual format and a fixed size that is set and forgot … some of the RRD data i convert daily to CSV and then used to update centralized database daily - i was trying to make it work on a influxdb currently for more options
