I’m trying to read the covid data from CSV file and want to push to influxdb 2.0,
Below is the JSON which I was using to push the data in influx1.8
json_body = [{
“measurement”: “covidMap”,
“tags”: {“Country”: row[3], “State”:row[2]},
“fields”: {
“Confirmed”: row[5],
“Deaths”: row[6],
“Recovered”: row[7]
How we can re-write the same JSON in a single POINT with multiple Tags and fields for the same timestamp
If your data has the same fields and tags (i.e. is the same series) then the most recent timestamp will overwrite your last point.
You can add tags to telegraf with:
Global tags can be specified in the [global_tags] section of the config file in key="value" format. All metrics being gathered on this host will be tagged with the tags specified here.
