So I’m pretty new to influxDB. I’m trying to create a new measurement (akin to SQL tables according to the doc), with three fields, two tags and the timestamp.
The writing of the data goes fine, but when I try to visualize it through the InfluxDBExplorer app, the data appears to be splitted into multiple entries; the _field value being the names of the fields I wanted to have, and the _value field being the actual individual values of the corresponding fields.
Here’s my Python snippet:
points = []
for row in batch:
point = Point("PERF").tag('ID',int(row[0]))\
.tag('service','LPV200')\
.time('2024-03-04')\
.field('avail',float(row[8]))\
.field('lon',float(row[1]))\
.field('lat',float(row[2]))
points.append(point)
write_api.write(bucket, org,points)
The rows are coming from a txt file that I’m reading through the script.
The table looks like this when consulted through the browser:
I’m not sure if the issue if the actual writing of my points or if the visualisation tool is just not displaying the data like it’s stored.
