Hi Telegraf team,
I would like to know if it exists a native MDStats collector for Telegraf (or if it’s planned) as it exists for node_exporter: https://github.com/prometheus/node_exporter/blob/master/collector/mdadm_linux.go?
Hi Telegraf team,
Hi @aurrelhebert ,
I don’t know if there are plans for it , I am sure somebody will reply.
It is currently not available , I checked it with the following command
telegraf --input-list |sort
have a nice weekend
You can use telegraf input_exec with simple python script via package mdstat:
pip3 install mdstat
# or pip install mdstat for python v2
Save script /usr/local/bin/mdstatus and give it x permision:
#!/usr/bin/python3
import mdstat
mdjson = mdstat.parse()
lines = []
for md in mdjson['devices']:
ln = []
ln.append('mdstat,')
ln.append('personality=' + mdjson['devices'][md]['personality'])
ln.append(' ')
ln.append('active=' + str(int(mdjson['devices'][md]['active'])) + ',')
ln.append('read_only=' + str(int(mdjson['devices'][md]['read_only'])))
lines.append(''.join(ln))
for disk in mdjson['devices'][md]['disks']:
ln = []
ln.append('mdstat-disk,')
ln.append('md=' + md + ',')
ln.append('disk=' + disk + ',')
ln.append('number=' + str(int(mdjson['devices'][md]['disks'][disk]['number'])))
ln.append(' ')
ln.append('faulty=' + str(int(mdjson['devices'][md]['disks'][disk]['faulty'])) + ',')
ln.append('spare=' + str(int(mdjson['devices'][md]['disks'][disk]['spare'])) + ',')
ln.append('replacement=' + str(int(mdjson['devices'][md]['disks'][disk]['replacement'])) + ',')
ln.append('write_mostly=' + str(int(mdjson['devices'][md]['disks'][disk]['write_mostly'])) + ',')
ln.append('replacement=' + str(int(mdjson['devices'][md]['disks'][disk]['replacement'])))
if len(lines):
print('\n'.join(lines))
Then add telegraf input:
[[inputs.exec]]
commands = ["/usr/local/bin/mdstatus"]
timeout = "2s"
data_format = "influx"
Thanks for your answer @sweb! I will give it a try
