hello,
I use telegraf instead of node exporter to collect data. There are some indicators that can’t be replaced.Hope you can help me.
metrics:
node_filefd_allocated
node_context_switches_total
node_filefd_maximum
node_filesystem_free_bytes
node_filesystem_size_bytes
node_filesystem_files_free
node_disk_read_time_seconds_total
node_disk_reads_completed_total
node_disk_write_time_seconds_total
node_disk_writes_completed_total
node_disk_io_time_seconds_total
node_disk_io_time_weighted_seconds_total
node_netstat_Tcp_CurrEstab
node_sockstat_TCP_tw
node_sockstat_sockets_used
node_sockstat_UDP_inuse
node_sockstat_TCP_alloc
