Hi
I have an influx instance that listens on port 8086.
I can access the UI on http://ip.ip.ip.ip:8086 and it works fine.
Now I would like to connect to influx through an apache proxy using a specific url.
I added this piece of code in /etc/apache/site-enabled/000-default.conf
<Location "/influx">
ProxyPass http://localhost:8086
ProxyPassReverse http://localhost:8086
ProxyPreserveHost on
</Location>
It works fine when I perform query using influxdb_client but the UI gives a blank page.
If I use firefox network monitor, I can see that the page tries to download fa4773d142.js but it should download influx/fa4773d142.js
Is there a way to configure apache or influx so that it takes into account the “influx” that should be added?
Hello @Anaisdg
No it doesn’t work. The problem is still the same. I have nothing in the error log.
Just this in access.log:
192.168.56.1 - - [26/Sep/2023:09:20:29 +0200] “GET /influx/ HTTP/1.1” 200 922 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/117.0”
192.168.56.1 - - [26/Sep/2023:09:20:29 +0200] “GET /fa4773d142.js HTTP/1.1” 404 492 “http://192.168.56.115/influx/” “Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/117.0”
GET /influx gives 200 which is fine
GET /fa4773d142.js gives 404 because it should be /influx/fa4773d142.js
/fa4773d142.js is modified to /influx/fa4773d142.js in the html code.
But then the js code sends GET requests for /21dc121c3b.js /78604747f7.js … etc … instead of /influx/21dc121c3b.js
Do you know if this possible to remap urls in js code as well? Or to configure the js framework with a base url?
Bests
Cedric
