I can open http://localhost:8086 web interface in my computer using putty+ssh tunnel to the vm
How can I open my influxdb web interface to public ip?
Thanks in advance
Hypothesis:
When I type influxd to run my server, it should listen my public ip instead of localhost
Open my 8086 port in vm firewall and in the instance
Hi @igormsg, if you’re running 2.x then the HTTP server’s default behavior should be to listen for connections on port 8086 from all network interfaces.
Like you mention, you’ll need to configure your VM with a public IP and the network/firewall rules to allow traffic on the port. The steps to do that will be specific to Google.
