I am trying to get InfluxDB v1.1.1 to listen on localhost only AND work with both IPv4/v6. Server is running on Debian 7.
Default, config, I can reach influx internally and externally:
[http]
The bind address used by the HTTP service.
bind-address = “:8086”
netstat -antp | grep “influx”
tcp6 0 0 :::8083 :::* LISTEN 813/influxd
tcp6 0 0 :::8086 :::* LISTEN 813/influxd
tcp6 0 0 :::8088 :::* LISTEN 813/influxd
curl -4 -sl -I localhost:8086/ping ← Works
curl -6 -sl -I localhost:8086/ping ← Works
Attempting to listen on localhost only using IPv6 I cant reach influx internally or externally using IPv4/IPv6:
[http]
bind-address = “[::1]:8086”
tcp6 0 0 :::8083 :::* LISTEN 1831/influxd
tcp6 0 0 ::1:8086 :::* LISTEN 1831/influxd
tcp6 0 0 :::8088 :::* LISTEN 1831/influxd
curl -4 -sl -I localhost:8086/ping ← Does not work
curl -6 -sl -I localhost:8086/ping ← Does not work
Attempting to listen on localhost only using IPv4 I can reach influx internally using IPv4 only:
[http]
bind-address = “127.0.0.1:8086”
tcp 0 0 127.0.0.1:8086 0.0.0.0:* LISTEN 3375/influxd
tcp6 0 0 :::8083 :::* LISTEN 3375/influxd
tcp6 0 0 :::8088 :::* LISTEN 3375/influxd
Not sure if I am missing something in the config or if this is just not possible.
