I was wondering as to how does an the index described in In-memory indexing and the Time-Structured Merge Tree (TSM) | InfluxDB OSS 1.8 Documentation help with a query like this “select avg(temperature.internal) where data_center = ‘10’”. From what I read in the above page the index has a key which is a measurement (temperature) , field (internal) and then a tag set (data_center=10,cpu_id=1).
So I visualize a key as a String like this ![]()
temperate.data_center=10,cpu_id=1.internal and this points to the blocks that contain the data and the time intervals.
Now if a query like “select avg(temperature.internal) where data_center = ‘10’” is done wouldn’t it have to scan all the index entries belonging to temperature and grep for all entries starting with temperature and has data_center=10. Wouldn’t this be slow?
