I have modbus telegraf input plugin to collect data from various devices (intervals = 5 minutes).
Need to write those data to 2 different influxdb bucket. 1st bucket with update intervals of 5 minutes(This bucket is with data retention policy of only 3 days storage). 2nd bucket with update intervals of 1hour( data retention policy of forever). -
I don’t want to create another separate sets of inputs to get data (because there are 77 devices currently and it will increase on the future)
Need suggestion on this situation. (is there a way to do this other than influxdb task script)
My current telegraf conf file looks like: (with 1st bucket with data retention policy of 3 days)
Need to add 2nd telegraf config for another influxdb
# Configuration for sending metrics to InfluxDB 2.0
[[outputs.influxdb_v2]]
## ex: urls = ["https://us-west-2-1.aws.cloud2.influxdata.com"]
urls = ["http://127.0.0.1:8086"]
## Token for authentication.
token = "influxdbRead_Token"
## Organization is the name of the organization you wish to write to.
organization = "OrgName"
bucket = "demo"
# Retrieve data from MODBUS slave devices
[[inputs.modbus]]
## Connection Configuration
## The plugin supports connections to PLCs via MODBUS/TCP, RTU over TCP, ASCII over TCP or
## via serial line communication in binary (RTU) or readable (ASCII) encoding
## Device name
name = "Device name"
interval = "300s"
## Timeout for each request
timeout = "1s"
configuration_type = "request"
tagexclude = ["host", "slave_id", "type"]
# TCP - connect via Modbus/TCP
controller = "tcp://192.168.0.103:502"
[[inputs.modbus.request]]
## Holding example
## All of those examples will result in FLOAT64 field outputs
slave_id = 33
byte_order = "CDAB"
register = "holding"
fields = [
{ address=3960, name="Active Energy", type="FLOAT32", scale=0.001, measurement="measurementName" },
## Holding example
slave_id = 34
byte_order = "CDAB"
fields = [
{ address=223, name="Active Energy", type="FLOAT32", scale=0.001, measurement="measurementName" },
[inputs.modbus.workarounds]
## Pause after connect delays the first request by the specified time.
## This might be necessary for (slow) devices.
# pause_after_connect = "0ms"
## Pause between read requests sent to the device.
## This might be necessary for (slow) serial devices.
pause_between_requests = "500ms"
## Close the connection after every gather cycle.
## Usually the plugin closes the connection after a certain idle-timeout,
## however, if you query a device with limited simultaneous connectivity
## (e.g. serial devices) from multiple instances you might want to only
## stay connected during gather and disconnect afterwards.
# close_connection_after_gather = false
## Force the plugin to read each field in a separate request.
## This might be necessary for devices not conforming to the spec,
## see https://github.com/influxdata/telegraf/issues/12071.
# one_request_per_field = false
## Enforce the starting address to be zero for the first request on
## coil registers. This is necessary for some devices see
## https://github.com/influxdata/telegraf/issues/8905
# read_coils_starting_at_zero = false
